Motor Questions: 36' RC
James S.
05-02-2005 20:17:09
Well, I have a few questions pertaining to a froze RC motor!
1: If my block was cracked, would I have antifreeze in my oil or can the block be cracked and nothing showing in oil or in my antifreeze?
2: If I would need to hone or bore the cylinders, or need new rings and pistons, would they be easy to find or are they a rare part to replace or find one size bigger?
3: How easy is it to tear one of these motors down to work on. I don't want to crack the motor if I don't have to. Or do you have to crack it to get the top half of the motor off?
I know some of these questions are common knowledge to those of you that know about motors. I am learning as I go along. The reason I'm asking these questions is because I don't want to get into something that is way over my head and end up spending to fix my mistakes then fix the motor. Thank you so much for your responses and patients. James
C. Amick
05-03-2005 04:24:06
 Re: Motor Questions: 36' RC in reply to James S. , 05-02-2005 20:17:09
It depends on where the cracks are in the block. Coolant can leak to the outside and not get in the oil. Here is one source for engine parts:
Link
James S.
05-03-2005 09:38:29
 Re: Motor Questions: 36' RC in reply to C. Amick, 05-03-2005 04:24:06
Thanks Mr. Amick for your help. That site is what I have been looking for.
James
