Case 470 front end
Brad (NY)
05-01-2005 17:06:06
1971 470 diesel, power steering. The front right tire wobbles in and out when going down the road. It doesn"t track straight, particularily at higher speeds. Is this the bushings in the wheel or is it something else? thanks, Brad
Dennis/Ohio
05-06-2005 03:35:40
 Re: Case 470 front end in reply to Brad (NY), 05-01-2005 17:06:06
You probably have some looseness on a tie-rod end but also has lost its toe-in? Wheels should be turned in slightly to preload steering linkage.
