Tire size, LA
Ralph NH
05-01-2005 13:10:27
When I get around to putting tires on my LA, what size should/can I buy for the rear? It came with old 15/30's. Thanks.
Walt Davies
05-06-2005 17:00:47
 Re: Tire size, LA in reply to Ralph NH, 05-01-2005 13:10:27
On the 18.4X30 tires on mine 1945 they say replaces 15X30 tires.
Walt
Walt Davies
05-03-2005 11:06:50
Caseman you are correct the 14X30 are now 16.9X30 and the 15X30s are now 18.4 by 30 I use the 18.4 X30 on my pulling tractor and it really helps a lot to get that extra bit of traction also I can carry a lot more weight in the tires. If you want to just show it then the smaller tires will work but I still like the look of the big ones I have two tractor one with the 14s and one with the 15 the larger tires do look a lot better on the LA. I have used it in mud and soft dirt for work and it never has given me any trouble But then we don't have that real sticky mud here.
Ralph NH
05-02-2005 14:59:11
So, I guess it's 16.9-30's. Thanks for the help!
jdacih
05-02-2005 12:57:30
I put 16.9x30"s on mine. my uncles old 41 has the bigger tires and almost rub the fenders, I would go with 16.9x 30 myself if I were you.
caseman-d
05-01-2005 20:46:14
replacement for the 15-30 is 16.9-30. Now if you want to exstend your rims you might put some 18.4-30's on it.
caseman-d
Bob in Australia
05-02-2005 01:16:34
 Re: Tire size, LA in reply to caseman-d, 05-01-2005 20:46:14
I have a 1944 LA with 18.4-30s on it. There is virtually no clearance between the tire and fender (which we call mudguard). In our heavy 'black earth' soil it clogs up with mud if there is any moisture around (now rare after 5 years of drought)
My 1949 LA has one 15-30 and one 16.9-30 and there is plenty of clearance.
oliverfan
05-01-2005 20:59:33
Caseman-d, If remember right the 14x30 tires became 16.9x30. And the 15x30 became 18.4x30.
Correct me if I am wrong.
