Need help on Case 320 Industrial
MikeOwi
04-30-2005 13:14:45
Normally I am on the green side with the Oliver guys, but I do own a Case 320 industrial and I need help on two items. The first deals with the power steering cylinder on the front axle. We have had this unit constantly leak, even though it has been repaired often. Now it leaks out of the servo unit on the left side of the ram that activates the power steering when you move the steering wheel. Is this a reasonable repair or should I try to replace it. If replacement is the only fix, where would one get the parts?
The second question deals with the hydraulic line hook ups to the backhoe. We had a bad leak in the wing type coupler. When we took it apart, we found some sort of valve. How does this valve work and how do I fix the leak? Thanks in advance.
Glenn/Mn
05-02-2005 19:28:01
 Re: Need help on Case 320 Industrial in reply to MikeOwi, 04-30-2005 13:14:45
I believe you are talking about the quick disconnect coupler when you refer to a wing type coupler should have male and female counter parts unless you have something queer. steering leak parts are G45077 seal kit for valve spool and G45079 for Cylinder but whos knows what is worn unless you disasemble, or the relief valve could just have something in it, take apart and clean it
