580 CK carb. problem
S. Conner
04-29-2005 23:03:37
I've got a 580 CK with a 159 engine and a Zenith carb. The number on the carb. is 13328. The engine has been running rough for quite a while and I've checked several other things and decided to rebuild the carb. It seems like there is a lot of wear at the throttle shaft. It doesn't look like there are bushings that can be replaced but I don't know for sure. I tried to get the two screws out that hold the throttle plate on but no luck yet. What I'm wondering is if there might be too much air being sucked in around this shaft causing the rough idle. I hate to spend $200 on a new carb. so I thought I'd see if anyone here might have some suggestions. Thanks for the help.
Glen in TX
05-02-2005 17:43:40
 Re: 580 CK carb. problem in reply to S. Conner, 04-29-2005 23:03:37
You drill it out for repair bushings but if shaft and butterfly is wore you will need those too and probably a kit, needle seat and gaskets. Let me know if I can price you those.
