930 Case
Jak
04-29-2005 07:44:45
I have heard lots of non turbo diesels out there run but this 1966 930 Case has a better tone coming from the exaust than any other I have heard.He is going to pull it in the antique pull coming up.On a good track will third be too much?Thanks fellas for any input.
Lamont
04-29-2005 13:39:06
 Re: 930 Case in reply to Jak, 04-29-2005 07:44:45
What size tires do you have? If you're running 38s you might power out in 3rd on a really good track. It should not run out of power in 3rd if you have 34s. We've pulled dad's old 930 NUMEROUS times in 3rd gear and have only powered out 1 time. We were running 18.4 x 38 Firestone 151s on the tackiest track I've ever been on pulling at 11,250 lbs. That same day I pulled over 300 feet in the 9500 lb. Classic. My brother pulled in the 9500 lb. Open and also pulled over 300 feet that day. It almost ran out of power but it started spinning just about the time I was going to clutch it. Everything was perfect that day. The track was just right, the power-to-gear was just right, and we had it weighted just right. The front wheels never lifted more 3 or 4 inches. You might try 3rd in the lighter classes and back up to 2nd if you go over 10,000 lbs. I agree that there's no better sounding engine than that 401D. Good luck.
Jak
04-29-2005 13:51:03
 Re: 930 Case in reply to Lamont, 04-29-2005 13:39:06
Running 34's on it.It would be nice if she would get a good bite and keep walkin down the track.Last night the neighbor from almost a mile away came right over after the 930 was fired up,he was sitting in his lawn chair and just couldn't stand it he had to hear that baby sound off.Has one half weight and two full weights on the front,probably need some more.A trycycle front was put on a few days ago and boy she looks good.Thanks for the info.
Lamont
04-29-2005 16:47:16
 Re: 930 Case in reply to Jak, 04-29-2005 13:51:03
What weight class are you going to pull? How high is your drawbar and what length from axle? You might not need any more weight on the front. They're awfully heavy. We never ran more than 6 weights on the front with 38 inch rubber with drawbar 20 inches high and 18 inches back from center of axle. If you're drawbar is lower you probably won't need that extra weight.
Don L.
04-29-2005 12:58:10
Put it in first on a good dirt/clay track. Maybe 2nd on gravel. Third gear on any track is not a option,with a stock engine. They are a slow running engine, and need to lug..... .
Good Luck
Don L.
