hydraulic oil problems
Scott Russ
04-29-2005 06:05:29
I have a case 530 tractor and loader , I checked the hydraulic oil level for the loader and it was low so I added enough to make the mark and oil is coming out the breather under the seat. I then checked the oil for the rear end and it was overfull. It all looks like hydraulic oil is it? and what is causing the loader oil to be low and go into the rearend and cause it to be overfull?
G.B.
04-29-2005 19:40:22
 Re: hydraulic oil problems in reply to Scott Russ, 04-29-2005 06:05:29
Hi, Scott.
The loader breathers are on top of the loader frame. If you have the loader only, the right side loader frame is the hyd. oil reservoir. Pump is in front of radiator.
vac400
04-29-2005 14:12:53
Scott,
I am would say that you have a seal gone bad between the transmission and rear end. If you have a parts manual look for a seal. If not go to your case dealer and he can look it up for you
jerry
