V-CASE CARBURATOR
SHANE HAGERTY
04-28-2005 17:55:46
RESURECTING A 1940 "V" CASE, AND THROUGH THE YEARS I THINK THE CARB WAS ROBBED FOR ANOTHER TRACTOR, I DUG AROUND AND THOUGHT I HAD GOTTEN AHOLD OF THE RIGHT ONE BUT THE BLACK SMOKE TELLS ME OTHERWISE.
DOES ANYONE HAVE A V WITH F124 ENGINE, AND COULD YOU TELL ME WHAT MODEL MARVEL SCHEBLER IT HAS?
THE CARB I HAVE IS A TSX 762 THANK YOU
Alberta Mike
04-30-2005 05:03:53
 Re: V-CASE CARBURATOR in reply to SHANE HAGERTY, 04-28-2005 17:55:46
There is a good article in the ARTICLES section here (see left hand margin) where the author takes a guy step-by-sttep through a MS carb disassembly and rebuild. I have found that almost any carb works on those Continental engines as long as the manifold bolts up properly. I have even reversed things like choke and throttle axles to get the right fit, or linkages can be changed and adjusted. One bit of warning in that changeover of the main jet, never remove ANY brass fitting from a cast iron housing without preheating the whole assembly slowly and carefully with a propane torch, or heat it in the barbeque for an hour or so. That old brass will twist off easily and you'll have nothing left but a paper weight. I'm not sure about pot metal carb housings.
Mike in UP of MI
04-28-2005 19:10:48
The standard carburator before serial #4518012 was TSX-42, after #4518012 was TSX-43. I have a 1940 VC and it has the TSX-42 carburator on it. Hope this helps, Mike
SHANE HAGERTY
04-29-2005 07:31:44
 Re: V-CASE CARBURATOR in reply to Mike in UP of MI, 04-28-2005 19:10:48
THANK YOU MIKE, THAT HELPS ALOT, DOCUMENTATION IS NOT TOO CLEAR ON THESE, IF I CANT FIND A TSX42 I WONDER WHY I CANT CHANGE THE POWER JET AND TUBE TO THE SAME SIZE AS THE TSX42?
THEN WHERE WOULD A GUY GET THAT INFO?
Jerry W
04-29-2005 16:22:46
 Re: V-CASE CARBURATOR in reply to SHANE HAGERTY, 04-29-2005 07:31:44
Shane
I am not absolutely sure but it seems that every TSX model Schebler I ever worked on had an identical power tube and and venturi. The only differences I have ever seen are which side the choke/throttle/idle screw and such are on. I have also noticed that the degree angle of the throttle butterfly varies sometimes from one to another but that only affects how the mixture acts as the butterfly is uncovering the idle mixture ports.
Maybe someone else with more knowledge of them can chime in?
Jerry
SHANE HAGERTY
04-29-2005 19:52:33
 Re: V-CASE CARBURATOR in reply to Jerry W, 04-29-2005 16:22:46
THE THROTTLE PLATE SAYS 10 DEG. ON THE ONE I HAVE.
IF THE TUBE IS THE SAME ON ALL, I WOULD ASSUME THAT I WOULD BE ABLE TO CHANGE THE POWER JET (IF I CAN GET IT OUT WITHOUT BREAKING IT)TO A SMALLER JET.
