What year did Case...?
JGarner
04-28-2005 10:38:41
What year model SC did Case switch to eagle hitch, foot clutch, foot throttle? Called about a 53 yesterday and serial no. indicated 53 model, but it had hand clutch and distributor. Were these rebuild add items, was foot clutch optional on late model SCs?
There is a 49 SC listed in the YT c;assified and it says it has eagle hitch. I touught this wa not available on SC until 52, or this a cobbled togater relic. What year did SC move up to 3.625" pistons? What was the horsepower with smaller pistons....3 5/8" pistons?
Walt Davies
04-29-2005 23:16:08
 Re: What year did Case...? in reply to JGarner, 04-28-2005 10:38:41
My 1943 Case SI had both a foot clutch and throttle. I wouls assume that they would fit on s model.
Les
04-28-2005 16:56:12
3 5/8" is the same as 3.625".
BTW, when we got the engine of my '44 SC opened up, we discovered it had 3 5/8 pistons. Obviously somebody had been in it before.
C. Amick
04-28-2005 14:55:54
1949 model SC's had a hydraulic lifting bail, so either and Eagle hitch has been added or the seller doesn't know what an Eagle Hitch is. The smaller cast iron pistons were 3.5" and produced around 23 hp. The hand clutch on the "left" side of the tractor was offered at the same time as the foot clutch.
JGarner
04-30-2005 10:17:53
 Re: What year did Case...? in reply to C. Amick, 04-28-2005 14:55:54
I believe he knew, because he described the hitch to me and it was definitely eagle.
So I need some years. You answered my question on hitches, I thought 52 was the first offering, but what year was foot clutch and left side hand clutch offered? I thought 53 and 54 only as these were the last 2 years for SC then it went to 400 series.
From what all you guys say, it looks like this was a cobbled together tractor that used pieces off more than one year and the piece with the serial number was a 49 as he indicated the number was 54XXXX something.
