Case with no tag.
Kurt Smit
04-27-2005 21:08:25
I purchased a Case modle S today and someone has taken the serial number tag off of it. Is there any other way to tell what year it is? Thanks in advance for any info.
Kurt
Jim V.
04-28-2005 02:00:36
 Re: Case with no tag. in reply to Kurt Smit, 04-27-2005 21:08:25
Kurt, look on engine flange by the air cleaner. Your serial number should be stamped there. If it is a seven digit number, subtact 4 from the first two numbers, that will give you the year.
Matt H
04-29-2005 11:17:23
 Re: Case with no tag. in reply to Jim V., 04-28-2005 02:00:36
I have a LA with the same problem.Is this true with my tractor too?
Jim V.
04-30-2005 02:01:28
 Re: Case with no tag. in reply to Matt H, 04-29-2005 11:17:23
Matt, this should be true for the LA also.
Kurt Smit
04-28-2005 05:50:57
Thanks!
H. Parker
04-29-2005 13:10:27
 Re: Case with no tag. in reply to Kurt Smit, 04-28-2005 05:50:57
I have a SC with no tag and there is no number on engine flange the block is a ribbed so I am thinking it may have been repaaced. Don't know the diameter of the pistons yet to know the bore.
