VAC wiring problem
Bob Knowlton
09-25-1999 19:53:56
Having troubles with the charging cicuit on a VAC, and would like to know where I can get a wiring diagram. Thanks
Mike
10-29-1999 10:56:33
 Re: VAC wiring problem in reply to Bob Knowlton, 09-25-1999 19:53:56
Assuming you have a cut-out on your generator, the field wire is grounded for maximum output. The armature wire is connected to one end of the cut-out and the battery wire to the other end. The other end of the battery wire runs into the ammeter. The other pole on the ammeter is hooked up to the kill switch, the kill switch to the battery and Voila! charging circuit.
Steve
09-27-1999 22:12:25
Bob,
Go to Yesterday's Tractors "Article Archives" and look under 3rd brush generators, which I presume that you have like mine, for some good schematics and info to follow. Remember to check all grounds for good clean connections, even the cut-out relay's base has to be grounded to the tractor to complete it's circuit.
