DC pull 12 tandem disk?
grapefarmer
04-27-2005 13:27:02
Can a DC pull a 12ft tandem disk on sandy soil?
Thanks
-Dave
dej(JED)
04-28-2005 11:10:40
 Re: DC pull 12 tandem disk? in reply to grapefarmer, 04-27-2005 13:27:02
There is no way a DC is going to handle a 12 foot disk. Only with the cylinder raised up to carry it down the road.
grapefarmer
04-28-2005 09:59:04
Sounds like a maybe... Oh yea and it a pull type with wheels and hydraulic cylinder. I guess I should look for a 8 to 10 footer.
Thanks
-Dave
Chico, TX
dctom
04-27-2005 16:44:02
piece of cake it you have duals on the DC be a load with out unless you carry the disk on the wheels, tom
John H-WI
04-27-2005 16:01:24
If its a wheel disk which I assume being 12' you might get a way with it okay if you can raise it up when you hit a tough spot. When I was home we only had the none wheel type which in our hills it made an M or A or a DC work for all they were worth to pull it and some times we had to narrow it up a little. The old ones you raised a lever and narrowed them up for transport.
Glenn FitzGerald
04-27-2005 14:41:13
We have a '51 DC we bought new. It is no slouch. Rear tires loaded with fluid. While we pulled it, our 10' John Deere tandem disk was too much for it. Glenn F.
