VAC drawbar pink leaking
jdman(MO)
04-27-2005 10:17:20
Any tricks to prevent a leak around the drawbar pin. Russ
1031D
04-27-2005 19:42:07
 Re: VAC drawbar pink leaking in reply to jdman(MO), 04-27-2005 10:17:20
The hole that the pin goes into doesn't go into the transmission sump, it's a blind hole. There is a bolt that hold the pin in that also goes between the trans case and rear end case that could be your source. Just RTV the darn thing if need be.
