case 411 b
ron brown
04-26-2005 19:58:46
hi was driving my case,(411b) under load ( pushing with front end loader) and the tractor just stoped moving, was sort of a(soft) pop and felt the coverter pedel go soft, I know the gears are still turning, tryed shifting other gears, had to shut tractor off to shift, but still would not move. can the hydromatic( i assume torqe converter ) get low on oil, the pressure gage for the hydromatic shows no pressure also, help....
Roger (Mi)
04-30-2005 05:51:26
 Re: case 411 b in reply to ron brown, 04-26-2005 19:58:46
The converter clutch pedal will always be soft, because you're only moving a valve spool when the pedal is depressed. I assume you have checked the Case-O-Matic oil level? You said you heard a "pop" sound , and now there is no pressure reading for the Case-O-Matic drive? If it happened that suddenly, something happened to the hydraulic pump for the Case-O-Matic drive. You can confirm it by loosening the Case-O-Matic filter cover and starting the motor momentarily. If no oil comes out, your problem is the pump. You'll need to remove the torque tube cover to get to the pump. Good luck!
