VA fluid questions
swamp farmer
04-26-2005 18:55:57
Does anyone know where I can find the drain plug for the hydraulic fluid? It's time to change it now that I've seen it.
Also, I asked a mechanic what weight would be best for a tractor that's used all year, just not very often. He told me 40 grade, but then said that transmission fluid would work really well, as they have a lot of the same characteristics. Has anyone ever tried this?
Can someone suggest a good brand of oil that has proved good in these old machines? I've heard that some have paraffin that breaks down after a few months. I'd like to find something I could change twice a year, spring and fall. Thanks for helping the rookie.
Joe (Wa)
04-28-2005 11:25:22
 Re: VA fluid questions in reply to swamp farmer, 04-26-2005 18:55:57
The drain plug is on the bottom of the torque tube just forward of the mating flange to the transmission (just inbd of the clutch pedal).
The factory oil for tractors that don't use the torque tube as a hydraulic reservoir was SAE 90, the same as used in the transmission. Unless you are having moisture problems, changing oil twice yearly is over-kill. The function of the oil is to lubricate the main drive shaft ball bearings and, if installed, the belt pulley drive gears.
If you have an engine mounted hyd pump and use the torque tube for a hydraulic reservoir, SAE 10 or general purpose hyd oil is suitable.
1031D
04-27-2005 19:19:16
I would suggest using CASE Hy-Tran in Eagle Hitch systems because it has anti-foaming properties. If you get foammy oil in it, you will hate to hear the racket that the pump makes. If you just have the belt pulley hydraulics, I've used SAE 30W oil in it with good luck, and I still cultivate with my '46. You should be able to use anything from ATF to SAE 30W to power steering fluid without hurting anything. The book does say to use the SAE 30W though.
swamp farmer
04-29-2005 18:11:33
 Re: VA fluid questions in reply to 1031D, 04-27-2005 19:19:16
My '51 has the engine mounted pump, so I'll probably go with a general purpose hyd. oil. It did look like it had some foam in it. When I told that industrial mechanic about the foam, he suggested replacing the hydraulic oil with tranny oil because it doesn't get foamy. I'd never heard that you could interchange them.
Many thanks for the info though.
While you've got the manual open, what engine oil is suggested - it's time for that to be changed too...
Joe (Wa)
04-29-2005 20:03:39
 Re: VA fluid questions in reply to swamp farmer, 04-29-2005 18:11:33
The hyd oil will have an anti-foaming additive, your foam was probably moisture and/or from using too heavy an oil for the small clearances in the hyd system.
While you have the torque tube drained, be a good idea to check the hyd oil return filter. It is located in the torque tube under the small 4 bolt flange below the fill plug. The original element was the edgewound type, cleanable in diesel, kerocene, mineral spirits, etc.
Torque tube holds about 2 gals. Fill to the lip of the fill plug opening with the hitch (if so equipped) draft arms raised.
Factory engine oil recommendation: SAE 5W -10�F and below
SAE 10W -10 to 32�F
SAE 20W 32 to 90�F
SAE 30W 90�F and above
Bare in mind this was non-detergent oil. Many people here use detergent 10W-30. I use detergent 30W year around. Any oil you use will be better than was available in the 50's.
Joe
1031D
04-29-2005 19:50:35
Well, I always use SAE 30W detergent oil. Works good.
Joe (Wa)
04-29-2005 21:39:59
 Re: VA fluid questions in reply to 1031D, 04-29-2005 19:50:35
SAE 30 is pretty heavy accept in hot weather. I think 10w-30 would be better if you prefer motor oil. Doesn't take much to blow a hole in the return filter element.
Joe
1031D
04-30-2005 22:44:06
 Re: VA fluid questions in reply to Joe (Wa), 04-29-2005 21:39:59
Sorry John, I was talking in his motor. I went to CASE and got a new filter for mine, it is some sort of plastic bead material.
