Case LA
RC Miller
04-26-2005 16:46:03
1944 LA engine stuck and looking for options. Parts, kits, etc. new or used.
Walt Davies
04-29-2005 23:39:39
 Re: Case LA in reply to RC Miller, 04-26-2005 16:46:03
I have a set of Multifuel Pistons and rods with good bearings Most of the rings are also in good shape but I would try to get a new set to be sure.
I live in Monmouth, Oregon I had a set of LP pistens sent to me and it cost less than $100 from Okie city, OK
I still have the crate and packing to ship then back.
Make me a good offer.
Texas Denny
04-27-2005 08:07:10
I agree with Jerry. You need to get out the pistons and look at the bearings when doing so (keep bearing and pistons in order so you can reassemble in order). I had a tractor given to me last summer with a stuck engine. I worked for 6 months trying to free the pistons - got 3 of 4 loose. Had to put the engine in my press to get out the fourth. I got it running a couple of months ago with my only expense being gaskets and new rings. Three of the cylinders cleaned up perfectly with a hone. The one I used the press to free had a couple of very small pits. All of the cylinders and piston were withing Allis specs on size as were all of the bearings. The engine uses no oil at all and has excellent power.
So, see what you've got first. Then come back and ask some more questions.
Jerry W
04-27-2005 06:28:35
Myself, I would want to know what I am up against first. I would at least pull the head and see the condition of the cylinders and pistons.
I have seen them where a minor clean up and new rings did the trick but I have also seen them where the mice p*ss had rotted a big hole thru a 1/4" thick sleeve.
Jerry
