800 Case o matic
Ryan Leasure
04-26-2005 10:45:35
I have a 58 model 800 COM wide front everything works on it. The problem i am having is it won't pull a load in COM drive. Example, I am driving up the road in direct drive 8Th gear starting up a steep hill, it starts to bog down so i push it down in to COM well the motor picks RPM back up and the tractor keeps moving for a little bit then it just slows down and stops moving what is wrong?
I just had this tractor split and put in new bearings and a new high range gear cause high range was out. So if i knowed what is wrong i can fix it.
Any help would be appreciated.
Thanks Ryan Leasure
comfortking
05-02-2005 08:56:50
 Re: 800 Case o matic in reply to Ryan Leasure, 04-26-2005 10:45:35
Hey Ryan
The C-O-M is nothing like a tourque or hydra power.
It is more like the automatic trans in your car, hinse the torque converter. Drive it like you do your car when in Case-o-matic, you will like this tractor if you remember that. You would not rev your car up half way and then drop it in drive
c hess
04-27-2005 16:49:27
Iwill add to all other replys you should check fith engine stopped that throttle moves to stop in back of injegtionpump. Check both foot an hand throttle. If it is not com will be slugish.
Texas Denny
04-27-2005 09:18:01
Your experience sounds about right. The Case-O-Matic can provide about 20 to 30% more pull power. If you need 50% more to get the job done, the tractor will go to zero speed. You have to match the power need to the gear being used.
My 800 needs some bushings in the transmission to make the direct drive work. I'm putting off the repair because it is so much work and parts are hard to find so I may need to make them.
Comfortking
04-27-2005 05:08:46
Sounds to me like the COM is operating fine. Down shift to 7th and run it in direct drive. If you have good pressure and no air noise such as lines sucking then I do not think you have a problem. A good test for this tractor would be in low 4th tied to a heavy load, at full rpm's and normal traction you should be able to slip the tires at shipping weight.
John Saeli
04-26-2005 18:42:35
Hey Ryan: Assuming the oil level is correct & you're using proper oil, sounds like the plates are wore, or other problems within the converter.
SHeiserman
04-26-2005 19:17:14
 Re: 800 Case o matic in reply to John Saeli, 04-26-2005 18:42:35
Could it be that in high gear, steep hill, and pulling a load that it (com) worked right? I hauled a load of straw in 4th, high side, in direct drive. As I'm sure you know, my 830 kicks all forms of a$$, but if the hill I ran into would have been 100 feet longer, I think I would have had a problem in that gear and range. The 800 has 8 gears instead of 4 w/hi and lo? Just curious.
Ryan Leasure
04-26-2005 19:42:22
 Re: 800 Case o matic in reply to SHeiserman, 04-26-2005 19:17:14
Yes, I just put all new oil in and it is at the correct level. This is my first Case with COM but i run oliver with hydra drive and International with TA and Massey with multi power. So i was jsut guessing that the COM worked like them, am i right? The COM will pull the tractor around to a extent, But sometimes pulling a hill it just slows down and stops like it ain't got no oil pressure, but it has like 120PSI. It don't do it as bad it the low side of the trans. I have not used this tractor for major work yet. As i have only bought 4 months ago after it has been sitting for 6yrs. I also thought that everything may have been working and it was just in to high a gear. I just thought it would stall out and not just stop.
Sorry about long post
Ryan
SHeiserman
04-26-2005 20:23:24
 Re: 800 Case o matic in reply to Ryan Leasure, 04-26-2005 19:42:22
I'll defer to John S. on this as he knows more about it than I do. Besides the t/a, I haven't run any of the other tractors you mention. As far as I know, you can't stall the engine as long as it's in com and it's working right. If you lose all ground speed and come to a complete stop, the engine will just keep going and heat builds up in the conveter. Not a good idea to let it sit very long w/o moving. Only supposed to use com to get moving and in the tough spots, and go back to direct when you're past it. If it won't start moving on its own in com, don't slam it into direct just to get moving. If it were me, I'd go back out to your hill and try a lower gear and see how it does. Takes some getting used to, but you'll like it once you do.
Ryan Leasure
04-27-2005 10:40:13
 Re: 800 Case o matic in reply to SHeiserman, 04-26-2005 20:23:24
I sorta figured it would not stall in COM. I will go out and try it in a lower gear. So far I love the tractor.
Thanks Ryan
