Painting
hankster
04-25-2005 04:00:58
was wondering the best process/way to strip and paint my '78 case 350 crawler ..... i have heard not to sandblast, any thoughts on that? also, what kind of paint, where to get, decals, etc etc etc..
this will be the first paint job for the ole girl
any help or advice would help, thanks !!!!!
JeremeSWMN
04-25-2005 20:33:29
 Re: Painting in reply to hankster, 04-25-2005 04:00:58
Hi, I work in a auto body shop and I guess everyone has there own way of doing things.I see no reason why you can"t sand blast the crawler as long as you make damn sure none of the sand gets inside the engine or transmission. I would not blast any of the tin(hood)because you could warp the metal. For tractors we"ve been using an epoxy primer(PPG Omni MP-170) then spraying enamel with hardener added. Case/IH dealer should have the enamel paint and a Carquest or Arnold Motor store will have the epoxy primer. Don L. at Rusty Acres might have your decals 1-507-433-0073 a.m. best time to call. Good Luck!
