VAC clutch what have I done
jdman(MO)
04-24-2005 20:07:46
Drove tractor yesterday, today removed left foot rest to service brakes, now I have no clutch. Could something happen by letting the clutch go back farther than normal because the footrest was off.? There is slight tension on the pedal, but nothing like it should be. Russ
C. Amick
04-26-2005 09:27:08
 Re: VAC clutch what have I done in reply to jdman(MO), 04-24-2005 20:07:46
There is a view of the clutch assembly on this web page. I think thw whole manual is on this site.
1031D
04-25-2005 13:38:58
Well, I had this problem once with my '46. I took the homemade platforms off to put correct ones on and once I got done I had no clutch. The trowout bearing was going bad and when I split it, I found that the throwout bearing fell apart and was laying in the bottom of the bell housing. Sometime with a clutch problem, the easiest way to find out what's wrong is to split it and take a look. Just some wishfull thinking, but when you took the platform off and the clutch pedal came back did the rod fall out?
jdman(MO)
04-25-2005 16:09:33
 Re: VAC clutch what have I done in reply to 1031D, 04-25-2005 13:38:58
Well I split the tractor and found the problem, a broke ball stud. Looks like it had been broken for a while. I guess when there is tension on it it will work, but when the clutch pedal went back, the clutch fork fell down. As you can see by my handle I am a John Deere person, and this is my first Case, guess I had better get some books, as this is a semi basket case. Thanks ..Russ
1031D
04-26-2005 11:33:51
 Re: VAC clutch what have I done in reply to jdman(MO), 04-25-2005 16:09:33
Well, if you need a ball stud, I have a couple extra trans quills laying around. If you want e-mail me. My brother-in-law is a deere guy, I'm J.I.CASE and IHC, so we're always giving each other grief, but that's the fun of it for us.
