Diesel Fuels
Chris Vangel
09-25-1999 11:05:08
I have just read an archive article about fuels, red or green, have not seen colors other than green at the truck stop. Not that I'm ready, but the truck stop had #1 diesel and #2 diesel. I don't know what to buy. I am just wondering for when the time comes. Is the color difference just for tax purposes or is it sulfer content or for off road use? Is Sulfer bad? Lastly, What is white gas? The tractor is '56 Case 401. Thanks in advance, Chris.
Jerrie Lott
09-25-1999 18:21:22
 Re: Diesel Fuels in reply to Chris Vangel, 09-25-1999 11:05:08
You cannot buy dyed diesel ay the truck stop, it is usually dyed red and if you get caught with it in an over the road vehicle the fine is something like $10,000. It is dyed to show that no road tax has been paid on it. #2 is what you would use most of the year,#1 is for cold weather because #2 will gel below a certain temperature and will not flow through the filter. White gas is what they called unleaded gas when it was a byproduct of refining and considerably cheaper than red gas or gasoline that contained tetraethyl or lead, as tractors were very low compression in the very early fifties and before it was all that was needed to run them. I believe it was about 82 octane but I'm not sure.
CHASS
10-09-2000 12:58:54
 Re: Re: Diesel Fuels in reply to Jerrie Lott, 09-25-1999 18:21:22
WHITE DIRV HAS MANY ADDATIVES TO IT THAT ITS RUNNING TEMP ARE LOW IN THE UK.
INTERESTED IN ARTICAL RED DERV CAN THE DIE BE TAKEN OUT OF THE FUEL IF SO HOW.
Q if it is a red die put in after distilation it can be removed. but how???
Q if it is distiled from the white also it can be removed but how? come on some one has the answer to the question.
