PTO Speed
Seedsntrees
04-23-2005 21:09:06
Does anyone know the PTO RPM of a 1030 CASE?
Tractor Data claims it to be 1,000 RPM.
Thanks
Roger (Mi)
04-25-2005 04:41:10
 Re: 1030 Case PTO speed in reply to Seedsntrees, 04-23-2005 21:09:06
I have a 1030 and it has a 1000 RPM PTO. Since the 1030 is rated at 101 horsepower, the amount of torque it puts (if it had a 540 PTO)would turn most PTO shafts into twisted piles of lethal metal if the PTO implement suddenly turned hard. When the PTO speed is increased, the amount of brute torque is reduced. It is possible to install a 930 PTO drive into a 1030 to make it a 540 PTO. To my knowledge, no 1030 came from the factory with a 540 PTO.
John Saeli
04-24-2005 08:50:53
 Re: PTO Speed in reply to Seedsntrees, 04-23-2005 21:09:06
Hey Seeds: I never saw a 1030 with anything but a 540, but some have said that they could be equiped with a 1,000 Shaft. If the shaft is course splined it's 540. If it is the fine spline then it's 1,000 RPM.
Seedsntrees
04-24-2005 09:06:22
 Re: PTO Speed in reply to John Saeli, 04-24-2005 08:50:53
Thank you for your input.
Regards,
