830 hydraulic pump
Patrick (Mich.
04-23-2005 17:58:02
I've got the hydraulic pump from my '63 830 removed and disassembled. This tractor uses the early style hydraulics (pre Comfort King) and had Eagle hitch originally. It does not look good internally! Does anyone know if the gears, pump body, and wear plates are available yet from Case Co., and if they are about how much they might cost? According to my I&T maunaul, it states that only the 930 six-speed tractors used wear plates on the hyd pump, but mine has them too. Also, does anyone know if the brake disc (#A11124) for the PTO is still available new? Thanks for your help.
John Saeli
04-23-2005 18:42:18
 Re: 830 hydraulic pump in reply to Patrick (Mich.), 04-23-2005 17:58:02
Hey Pat: I rebuilt a pump for an 800 last year & I think they are the same pump. Some parts were "No Longer Furnished". Some of the scored parts I refaced myself using a flat surface & emery paper. Good Luck.
discount dave
04-25-2005 18:58:49
 Re: 830 hydraulic pump in reply to John Saeli, 04-23-2005 18:42:18
I took a pump from an 800 and put on my 830 and it worked fine. I think the pumps from the 400,700,800,730 and 830 all interchange, Dave
DKase
04-23-2005 18:21:17
Last time I checked most of the pump parts were available. It is pretty easy to spend $800 on one. I bought a CK tractor in better condition for less money than it would have cost to fix the hydraulic pump. DK
