Distributor part ID needed, 1959 Case 310B w/L/BH,
Ed in Maine
04-23-2005 16:01:53
third party image
This is the skinny long bolt that connects the points to the coil. It needs to be an insulated from the chassis of the distributor but the plastic has cracked and shorted to the chassis. I rigged it to work but want to find a reliable replacement. It took a while to find this short, replacing the coil, cleaning the points, etc..... then I realize the plastic cracked just enough to arc then biased with 12V! Sad that it took an electrical engineer that long to diagnose!
Can I get this part from Napa? or would it come with a new distributor? Thanks! Just got this tractor and I will be on the board frequently so email anytime!
Ed
Ed in Maine
04-24-2005 04:34:10
 Re: Distributor part ID needed, 1959 Case 310B w/L in reply to Ed in Maine, 04-23-2005 16:01:53
Thanks for the PN's and the tip on hitting the yards. Will look for a plate when I finally get the tractor home.
Ed
Joe (Wa)
04-23-2005 21:12:24
Some of the 300B series used Delco-Remy distributor p/n 1111909. There should be a nameplate on it.
These are old Delco-Remy p/n's for that distributor.
Stud, terminal..... ...1916806
Insulator, inner..... .1916805
Insulator, outer..... .1914142
Joe
Joel Dube
09-05-2005 03:54:35
 Re: Distributor part ID needed, 1959 Case 310B w/L in reply to Joe (Wa), 04-23-2005 21:12:24
Would anyone know the part numbers for the points, condenser, cap, etc. for the Delco-Remy 1111909 distributor?
Thanks,
Joel
wayne2
04-23-2005 20:52:07
Ed, theres zillions out there, patience and a little exploring(yards etc.) could save $$.
Jerry W
04-23-2005 18:29:11
I get insulated terminal parts from my local electric motor rebuilder. That looks like all you need.
Jerry
Ed in Maine
04-23-2005 19:04:03
 Re: Distributor part ID needed, 1959 Case 310B w/L in reply to Jerry W, 04-23-2005 18:29:11
Thanks Jerry, will check with a local starter rebuilder place. It is a Delco cap so I would think there are a slew of parts available somewhere. Thanks for the reply,
Ed
