880 DB loader
Bernard le m�ca
04-23-2005 11:06:40
Hi, a friend have a 880 DB, with a loader. The dealer tell him, it have a power-behond plate, from Case-IH, to run the oil from the pump to the loader valve then return to the hitch valve. The plate go to the top of the remote valve, with one hole, for pressure and the other, for the return. The plate cost $ 720.00 CDN. I want to make a plate , from a 3/4x4x8, stell plate, but I should drill and tap, for 1/2 NPT fittings and i'm not sure the pressure and return port, from the top of the remote valce. Does one of you have the tric. Thank you. Bernard le m�cano Qu�bec Canada
jimont
04-23-2005 13:29:09
 Re: 880 DB loader in reply to Bernard le m�cano, 04-23-2005 11:06:40
Try Elmer at www.davidbrowntractortips.com
He makes the power beyond adapter out of aluminium much , much more reasonable than CaseIH.
