Clutch shaft end play ???
Rodent
04-22-2005 17:39:39
On a Case model V, what would be the in-out end play when installing a clutch shaft? Right now it's a little bit sloppy at 0.015" and I am going to have to machine down the bearing carrier to get it a bit tighter. The shims I have just make the clearance more so the measurement I gave is without any shims.
Bruce Nelson
04-23-2005 04:43:06
 Re: Clutch shaft end play ??? in reply to Rodent, 04-22-2005 17:39:39
The CASE manual says it should spin freely, but have no end clearance. If you have .015" now, you will need to mill .015" off the bearing carrier. Maybe take more and add a shim if you need too. Bruce
