Brake balls , springs , boots
Wayne J.
04-22-2005 10:10:23
Hay john Seali Some one was hunting for DC brake boots and were suggested to contact you. I am hunting for the balls, springs,& boots for the Case 401 i am re-doing. I have part numbers.email open i think Wayne J.
Doc Larry
04-22-2005 20:02:03
 Re: Brake balls , springs , boots in reply to Wayne J., 04-22-2005 10:10:23
Wayne,
I just purchased brake balls and springs for my 401 from a Case dealer. Not sure if the boots are available but suspect they are. Apparently these brakes were used on later tractors.
Larry
Wayne .J
04-23-2005 07:18:11
 Re: Brake balls , springs , boots in reply to Doc Larry, 04-22-2005 20:02:03
Thanks Larry . hear are the part numbers for the brake parts i need cap or boot 08762ab need 2 springs 08780ab need 6 balls 08296ab need 6 It had broken springs & pitted balls. The boots were hard & cracked ,disc almost like new. Wayne J.
Joe (Wa)
04-23-2005 10:31:21
 Re: Brake balls , springs , boots in reply to Wayne .J, 04-23-2005 07:18:11
I don't have a 401 parts manual but can cross the p/n's you listed. Note that the first character in the old p/n is the letter O not a zero. Dealers sometime list under either.
Boot.....O8762AB...A27465
Spring...O8780AB...A30897
Ball.....O8296AB...211-15
Case dealer should have the parts you need. I just finished a brake job on a 310, just needed cleaned up and new balls. No Case dealers in my area. I bought the balls @ the link. Type "chrome E52100 alloy steel ball" in the search thing.
Joe
Wayne J.
04-23-2005 14:55:14
 Re: Brake balls , springs , boots in reply to Joe (Wa), 04-23-2005 10:31:21
Hay Joe thanks for the cross reference on the parts numbers. My YT e-mail wont release e-mail to me. My e-mail is [email protected] try to contact me that way if you tried to e-mail me. Wayne J.
Doc Larry
04-23-2005 16:35:10
 Re: Brake balls , springs , boots in reply to Wayne J., 04-23-2005 14:55:14
Wayne,
You might want to check the seats that the balls ride in to make sure they aren"t pitted too badly. These are round, concave, and set in the disks. They are very hard steel? I think. Several of mine were badly rusted and had to be replaced. They can be tough to get out, so I would recommend only replacing any that are really bad - not cheap either, as I recall.
Larry
