bosch pump on 1210
jim on van isle
04-21-2005 02:34:34
there is a small plate at the back of the robert bosch inj. pump on our case 1210 & it has a plug in it.my question is,which position should the plug be in (is it a drain plug or a level plug for the oil level in this self contained pump,as the plate can be put in different positions.
kyhayman
04-21-2005 11:29:45
 Re: bosch pump on 1210 in reply to jim on van isle, 04-21-2005 02:34:34
take this at what it costs you :-). As I recall the Bosch pumps on the late 1210s did not have a check plug only a drain plug. Drain oil and then measure to fill (I used a syringe). The Simms pumps did have both drain and check plugs with drain on the bottom and check on the side.
jim on van isle
04-22-2005 10:58:24
 Re: bosch pump on 1210 in reply to kyhayman, 04-21-2005 11:29:45
my next question is -how much oil to put in ? thanks - jim s
