clutch brake-belt pulley
farmerKen
04-20-2005 18:04:58
I have a 1936 Case "C" that I recently restored but I am looking for the clutch brake-belt pulley to finish the restoration.The owners manual says that it is a two piece constuction that is bolted together. It has a diameter of 10.25 inches and a face of 6.25 inches. The shaft diameter is 1.75 inches. If you know the whereabouts of one please let me know.
L.C.Grey
04-21-2005 18:29:05
 Re: clutch brake-belt pulley in reply to farmerKen, 04-20-2005 18:04:58
The pullies for the C series were actually made in two pieces. The inner piece fits on the shaft and has half the width of the belt driving surface on it and the inboard outside edge acts as the clutch braking surface. The outer piece bolts onto the inner piece and completes the full width of the belt pulley surface.
I'm sure theres several people on here who could procure one for you, but the first to come to my mind is always DonL at Rusty Acres.
Contact him at [email protected] or (507) 433-0073 (mornings best)
FarmerKen
04-23-2005 09:01:56
 Re: clutch brake-belt pulley in reply to L.C.Grey, 04-21-2005 18:29:05
Sounds like the pulley that I need, the problem being is that nobody seems to have what I need. Some say they have it, then come to find out it is either the wrong diameter or the shaft is tapered and mine is straight. If you can think of others please let me know. Thanks Ken
L.C.Grey
04-23-2005 16:06:33
 Re: clutch brake-belt pulley in reply to FarmerKen, 04-23-2005 09:01:56
A guy close by here has a couple of CC donor tractors at his place. If I can run across him I'll see if the pullies are still there.
I was wondering if an early D/DC pulley wouldn't interchange on a C. Anyone know?
