vac Charging
mikefromiowa
04-20-2005 14:22:54
I was mowing the other day with the ole VAC and noticed that the amp guage was showing about 18 amps. I had the light switch in position #1. It didn't change with position #2, but did drop to about 9 amps with position #3(lights on). I didn't think these generators would put that much out. It typically has always run about about 0 in position #1. I know it should be about 3, but I did install a new resistor and that had cut it down some. I can't find much in my manual to help. any ideas? I believe I used a 6 ohm resistor. I haven't looked to see if its fried yet. Could the cut out be stuck?
thanks in advance
Mike
mikefromiowa
04-21-2005 05:26:16
 Re: vac Charging in reply to mikefromiowa, 04-20-2005 14:22:54
Well, I think it may be the switch. I was mowing last night and played with the switch, the first position is now back where it should be (or where it was). the second position still shows way too much amperage. Guess I'll keep digging
Eric Foster
04-20-2005 18:38:54
I thought the resistor was 3 ohms. If I'm wrong, please let me know. I've been trying to get my charging rate set for a while now.
Thanks,
Eric
mikefromiowa
04-20-2005 14:45:36
yes, it does have the adjustable cutout. I forgot to add, that while mowing, I noticed the band that covers the brushes had opened up. It didn't fall off. I closed it back up, but to tell you the truth, i'm not sure what brush is the 3rd and how to move it.
C. Amick
04-20-2005 14:38:32
Does your generator have an adjustable brush on it? I don't think it would be the cutout. I think the cutout just shuts off the flow of electicity? I thought the resister just cut down the amperage going to the lights? Perhaps someone smarter than me can chime in. :)
M5G
04-20-2005 18:25:48
 Re: vac Charging in reply to C. Amick, 04-20-2005 14:38:32
I can provide info from a manual that I have to maybe shed some light for you....I hope!
GENERATOR
The generator used on �VA� Series engines is belt driven, adjustable third brush type having a maximum cold output of approximately 12 amps. The charging rate is adjusted by shifting the position of the third brush, which can be reached by removing the cover band on the rear end of the generator. The movable third brush is on top and a little toward the engine. Moving the third brush in the same direction as the rotation of the armature increases the rate of charge, while movement opposite the armature rotation reduces the rate. A rate of charge of over 15 amps will tend to overheat the generator.
The amperage output of the generator can be controlled and regulated by the light switch which is mounted on the instrument panel. The switch has three positions.
The first position, that is with the switch button in as far as possible, connects a resistance in the field circuit of the generator which reduces the generator output to 3 amperes but does not turn on the lights.
The second position shorts out the resistance, giving the full output of the generator, but does not turn on the lights.
The third position turns on the lights, and also shorts out the resistance, giving full output of the generator.
Whenever the generator is operated without the battery connected in the circuit, the field lead should be disconnected. Failure to do this will cause the generator to burn out.
