oil leak 311b
theforks
04-20-2005 12:14:16
When I drive my 311b, oil foam leaks out from under the transmission shifter plate, my service manual is not here yet so I"m not sure what might be wrong. Any help would be appreciated.
Thanks
Joe (Wa)
04-20-2005 13:13:09
 Re: oil leak 311b in reply to theforks, 04-20-2005 12:14:16
Check the transmission oil level. Plug with dipstick is located just aft of shifter cover.
Also the speedometer cable seal may be missing on the left front of the shifter cover. Check the breather clear (under the seat).
High oil level is generally due to:
1. Rain water leaking into the sump (shifter boot?).
2. Hydraulic oil leak from torque tube reservior via Eagle hitch piston or main drive shaft seal.
Joe
