Sc hydraulic swivels
AUSTEX
04-19-2005 14:32:02
I had the hydraulic hose connection/swivel with the restricter valve in it for lowering the three point break recently on my SC. Does anybody know if this is available with a new part number ? The local dealer has had no luck with the old #.
thanks
Geoff
C. Amick
04-20-2005 06:47:14
 Re: Sc hydraulic swivels in reply to AUSTEX, 04-19-2005 14:32:02
According to the post below: Case has them. Part number A30872. They cost $64.01 each.
Bruce Nelson
04-19-2005 16:37:45
The one with the lowering speed valve built into the fitting is not available from Case. You can use one of the other fittings, (like the fitting that connects the pump to the raise hose). It will not control your lowering speed.
rgorange
04-19-2005 16:02:24
Geoff,
Scroll down about a page right here!
