CaseIH885 loss of power
PhilCaseinWPA
04-19-2005 06:18:28
Last evening I was plowing and everything was working fine. CaseIH 885 w 3x16 mounted plow. I had to get off the tractor to move a piece of plastic mulch from the field (1 min). When I started to plow again the tractor lugged down and barely made it the last 10 feet to the end of the field. Well the fuel was at 1/4 on the gauge and I know that it is lower than it shows so I went and added some fuel. Tractor ran fine w/o any load back to the fuel tank. I went back to the field and the same thing happened. RPMs are at 2100, drop the plow, and she lugs down to 1200. Increase the throttle and no more power. Had to shift down to 2nd gear to finish the pass and even then it was lugging. When I got to the end of the row and raised the plow she ran fine. I went back to the shed and parked it. When I get home today I'll try to figure it out. Maybe that red tractor was just tired of pulling that green plow but I don't think that was it. I think I know what the problem is. This happened once before and is a simple fix but I'm posting to get all of your thoughts in case I'm wrong (been known to happen a few times). I'll let you know tomorrow how I make out. Sorry for the long post and thanks in advance. (I'm posting this on the tractor board board also)
