Case 800 Powercel
dbock
04-18-2005 15:19:53
I just had the injector pump on my 800 rebuilt and while I was at it I had the fuel injectors checked out. It now starts and idles very well, but when I give it fuel it starts to miss and it isn't burning all of the diesel. The book said to clean the powercels. I was able to remove the screw cap and the outside part of the powercel, but I couldn't remove the inner half. What is an easy way to pull the inner half of the powercel or is this even my problem?
Pat Tercho
04-18-2005 16:53:44
 Re: Case 800 Powercel in reply to dbock, 04-18-2005 15:19:53
The inner PowrCell unit is tapped for a puller, but you could just use a brass or wooden dowel from the injector bore side of the engine to gently drive it out. It's worth checking out, could be carboned up or even burned if the injectors were bad for quite a while.
