630 Hydraulic Hook Up
K-Mo
04-18-2005 10:24:54
I can't seem to figure out how to connect a two-way cylinder to the remote hydraulics.
The owner's manual says to move the lever back and forth to relieve the pressure. I tried with the tractor running and not running. Tried to connnect while moving the lever. Just can't get there from here.
Can someone help?
K-Mo
Roger (Mi)
04-19-2005 04:44:20
 Re: 630 Hydraulic Hook Up in reply to K-Mo, 04-18-2005 10:24:54
Many of the 30 series tractors had a hydraulic interlock on the remote control valve to prevent the lowering of implements when the tractor was not running. Can't hook up a remote cylinder hose? Turn the motor OFF! Moving the lever back and forth with the motor running will do no good! With the motor off, use a punch to depress the button in the center of the tractor's hydraulic hose connection. That will release the tractor's hydraulic pressure allowing the remote cylinder to be connected. Just make sure the remote cylinder has no pressure on it.
Roger (Mi)
04-20-2005 03:29:52
 Re: 630 Hydraulic Hook Up in reply to Roger (Mi), 04-19-2005 04:44:20
It really isn't required to turn the motor off to release the pressure in the tractor's hydraulic connections. It's just safe and removes the possibility of bumping the remote control lever during the pressure release process which would put pressure one of the tractor's hose connections again.
c hess
04-18-2005 18:06:54
Relieve some or most of pressure on cylinder.Make sure ends are not rusty.Idle engine an push leaver very small distance to release pressure . or stop engine an move leavers back an forth. i assume you are aware you have to pull back on tractor hose end at same time as you push cylinder end in.If that doesnt you may need to hit protruding small ends on both cylinder an tractor ends. Some times they can ge very stuborn . good luc k
