730 com drive
730
04-17-2005 20:29:31
have a 730 caseomatic drive that has low clutch pressure - seems to run right about 135 psi when the tractor is wide open - lower pressure at lower engine rpm's- was told to replace the filter and change the fluid - are there any other filters other than the 1 by the battery box - the lines seem to run up by the power steering box - what kind of oil should I use - was low when I started and was told to add Universal transmission/hydrolic oil - is this right or too heavy - others say ATF - or is case TCH available - any help would be appreciated -thanks!!
Roger H
04-18-2005 09:45:56
 Re: 730 com drive in reply to 730, 04-17-2005 20:29:31
Our 830 had ATF for years until 4 years ago when we put TCH in it, it is getting switched back to ATF at next oil change. ATF works better in the winter since it's thinner, not as much drag in the convertor so gears dont grind so bad.
wayne2
04-17-2005 20:56:07
Filters have been known to be placed in front of Radiator(follow lines)
wayne2
04-17-2005 20:56:00
