Selectamatic problem
S�ren
04-17-2005 02:00:49
DB 1200 selectamatic.
In T.C.U. The lift works with wery litle power and the function is reversed, this seems to be normal, but with the selector in the center position (lift i think) Nothing hapens at all, no sound and no lifting.
I just bourght the tractor and the first thing i did was to replace all filters & fluids.
Could it be air in the Selector mechanism.
Please help Best regards
S�ren
gary case
04-17-2005 06:06:23
 Re: Selectamatic problem in reply to S�ren , 04-17-2005 02:00:49
soren, i just did about the same thing you didon my 530,i over filled the hyds with fluid a little and the real problem was the dual controls. the tilt lever was full of rust. took it apart and chipped some of the rust off the spring and washers and screw. oiled them up good and put it back together and worked great. i also just had to check out the up and down lever and that's when you have to be carefull of the ball bearings and springs if you take the the sleeve off. had a h.ll of a time getting it back together. finally used a narrow hose spring aropund the piston, leaving it loose enough to slip the 2 remaining bearings in and screwing it to compress the bearings together. then put the outer sleave on and with a sudden blow with my hand pushed it on and down holding the lever on the other side forcing them together till the balls slipped in there grooves. fired her up and touched the controls and man was that satisfying when it worked. now with that said there could be a plugged or constricted line and the linkeage adjustment. this is only backyard mechanics so take it for it's worth and good luck. gary
Soren
04-17-2005 10:47:44
 Re: Selectamatic problem in reply to gary case, 04-17-2005 06:06:23
Thanks i just found out that it could be air in the system, i�l fire her up in the morning and see how she behaves before tarying the hydraulicks apart
Best regards
S�ren
