Parts for Model S
Gordon Richmond
04-15-2005 19:24:17
I'm helping a friend fix his Case Model S. It wouldn't start due to lack of compression. Removed the head, found two bent pushrods, both on exhaust valves. All four exhaust valves were fully or partially stuck due to carbon deposits in the lower area of the guides.
Is this a common problem with this model? Is there any remedy to prevent this from recurring?
I managed to straighten the bent pushrods, but I'd prefer to use new or good used ones. Are any available?
Needless to say, I could also use a top-end gasket set.
Thanks in advance,
Gordon Richmond ( Trochu, Alberta )
C. Amick
04-18-2005 09:46:45
 Re: Parts for Model S in reply to Gordon Richmond, 04-15-2005 19:24:17
The only valves that I've seen stuck were on tractors that had been sitting for quite a while. Make sure that engine oil is reaching the head and that things are being lubricated. Email me and I can give you some sources for parts ([email protected]).
caseman-d
04-17-2005 18:38:58
Have you tried your Case dealer for the parts. All S series engine parts will interchange.
caseman-d
