Case 400 diesel wiring harness
Jeff Gregrow
04-15-2005 11:55:40
Does anyone make a wiring harness for a Case 400 diesel?
C. Amick
04-18-2005 08:20:58
 Re: Case 400 diesel wiring harness in reply to Jeff Gregrow, 04-15-2005 11:55:40
Have you emailed or called John Brillman to check with him? (brillman.com)
matt ky
04-17-2005 07:42:12
you might check Agri-Services Wiring Harness Specialist(wiringharnesses.com). I haven"t bought anything from them; their web site says they can make what you need.
Jeff Gregrow
04-18-2005 04:29:12
 Re: Case 400 diesel wiring harness in reply to matt ky, 04-17-2005 07:42:12
I think that I talked with them last fall and they have not made one for a 400 but would if they had a pattern-- which I do not have since mine has been cobbed up over the years. I suppose I could make one up myself, but I bought and installed one on an old Moline and it was so easy and relatively inexpensive, I'd like to find one for the Case. Thanks.
Wayne J.
04-15-2005 19:51:22
Hay Jeff there arnt that many feet of wire in a 400 diesel wiring harness. You can make that wiring harness light wires and all in a couple of hours. napa auto parts has cloth wiring cover. Wayne J.
Pat Tercho
04-15-2005 18:20:59
Jeff-
I have not seen this, but it doesn't mean it's not out there. I redid the wiring on my 400 one wire at a time with bulk wire and crimp connectors. There's really not that much to it, and the schematic in the manual is pretty good. If I can do it and have it work, I'm sure you could!
