311B EAGLE HITCH
N CASE
04-15-2005 05:02:55
the adjustable side arm, with the crank, on my eagle hitch has striped some of the treads, can the arm still be purchased from case ih ?
Case300
04-15-2005 09:51:02
 Re: 311B EAGLE HITCH in reply to N CASE, 04-15-2005 05:02:55
N CASE; I had the same problem, I took and cut it off below the theads, put a taper on the end and them welded a 3/4" new shaft with the same thread on it, can turn them on the lathe, welded it good, smoothed it up on the lathe and is like new. Can also do the same with a nut for the top female thread, cost less also.
J Blahitka
04-15-2005 09:07:49
Hi. I checked with a case dealer up here in canada and they said this part is on longer available. Try Ken Bonney at 1 541 564 0661 I think he might have the part you are looking for . joe
