930 CK Hyd shaft pilot bearing
todd08
04-14-2005 20:18:46
Does anyone know the part number for the pilot bearing for the hydraulic pump shaft? The one next to the gear and chain. Is it a bronze bushing or roller bearing? Mine definitely has a bunch of play.
DKase
04-15-2005 06:21:05
 Re: 930 CK Hyd shaft pilot bearing in reply to todd08, 04-14-2005 20:18:46
You must be talking about a 930 Standard tractor, and the bronze bushing inside the sprocket. I have interchanged them with the live PTO DC's. My parts book only covers the draft-o-matic tractors, so I cannot help with the part #. If the bushing is bad make sure the shaft if OK. Most of the time if the bushing is bad the shaft is bad also because they were run dry.
