DC transmission
Scott KY
04-14-2005 18:17:35
My 50 DC has a problem shifting into neutral when coming out of reverse or second. In other words when the shift lever is in the neutral position it will still be in the gear it was shifted out of, either second or reverse. If I wiggle the lever into just the right position it will go in neutral. Think it might be a bent shifter fork?
DKase
04-14-2005 19:17:24
 Re: DC transmission in reply to Scott KY, 04-14-2005 18:17:35
Of the 7 that I have that run I think 3 or 4 of them are that way. The end of the shifter is warn. Pull the shifter out and build it up a little and it will be fine. The newer shifters with the bend do it quicker than the older ones with the straight shifter. LOL DK
Scott KY
04-15-2005 04:28:26
 Re: DC transmission in reply to DKase, 04-14-2005 19:17:24
How much do I build them up? I suppose you mean on each side of the shift lever.
Camboted
04-16-2005 00:09:32
 Re: DC transmission in reply to Scott KY, 04-15-2005 04:28:26
Scott, I don't have the exact dimensions but they are about 3/4" in diameter (about the size of a nickel), 1/4" thick and have a flat bottom, maybe 3/8-1/2" ground flat perpendicular to the shift lever.
Camboted
04-15-2005 04:07:29
DKase, you got it right. Every one of ours needed rebuilding. What really makes for a hard surface is get some pieces of broken piston rings and weld them on before grinding them down to the proper shape.
