Need engine oil pump for a 870 Case diesel tractor
Tackit
01-11-2006 12:42:11
I am posting for a farmer friend in Indiana who needs a engine oil pump for his Case 870 Diesel tractor. He tells me that the pump has two cast iron counter weights and two gears.
On the pump there are two numbers A61895 and on the end of the pump A61129
Thank you for any help locating one
d-c-741
01-13-2006 15:34:19
 Re: Need engine oil pump for a 870 Case diesel tra in reply to Tackit , 01-11-2006 12:42:11
The part you need Costs between $500-650 for used ones ! there are 2 different ones used / a 2 gear and a 3 gear ,the gear that drives them one the crankshift are allso have to match the balencer !
tackit
01-13-2006 18:31:10
 Re: Need engine oil pump for a 870 Case diesel tra in reply to d-c-741, 01-13-2006 15:34:19
d-c-741 I was told the three gear is for a gas engine and it's driven off the camshaft If I am remembering right.
Tackit
01-11-2006 18:01:31
Thad I contacted my friend and told him you have one and to call during the day. He said he will give you a call tomorrow.
Thanks for responding. Tackit
Thad
01-11-2006 15:50:06
Hello I have one call 417 498 6571 days. thanks Thad
