Case SC No engine power
Vineyard Matt
04-14-2005 15:53:05
well I got my SC up and it purs like a kitten now though i hooked my brush hogs pto to it, and also in the higher end grears the engine is really struggleing and begins to pop this i know is not right especially for running the pto and moving in 1st it is really struggleing. any ideas on what it could be. It idiles just fine and runs in 1,2 fine no struggle but in 3,4, and pulling with the pto it seems like it losses it's power. im open to any ideas, carb needing cleaning?, timing? im almost sure the engine itself is fine i really inspected it when cleaning it up.
let me know
Matt
C. Amick
04-18-2005 05:19:33
 Re: Case SC No engine power in reply to Vineyard Matt, 04-14-2005 15:53:05
I would try looking at the timing. I would turn the magneto or distributor a little and then put the tractor under load to see if helps and repeat the procedure.
Walt Davies
04-16-2005 12:25:33
Sounds like you might have acouple of spark wires crossed I did on a car once and it ran pretty just didn't have any power. Look on the head for the firing order and check to se that you are going in the correct direction on the mag. also check valve clearance a tight valve can cause alot of trouble or a week spring I had aweek valve spring on my LA boy what a differance in power when I fixed that.
Vineyard Matt
04-18-2005 05:15:56
 Problem Fixed in reply to Walt Davies, 04-16-2005 12:25:33
I found the timing was off on my ole' SC she runs like a dream now. thanks everyone for you help
Ill post a picture of the tractor on the site with are vineyard in the background
-matt-
