Case L - Case LA air cleaner
Steve (DE)
04-13-2005 19:29:36
I'm slowly repairing/replacing parts on my 1930 Case L. Just got to the air cleaner. I loosened the holding strap from underneath, and dropped down the "thin used oil" container. I was expecting, per the Case L parts books, a partial screen of some sort, and a separate gasket. I found a steel gasket with an integral screen which screwed into the bottom of the top half of the air cleaner (with fillister head screws). I'm thinking, from the suspicious Flambeau Red on the holding strap, that maybe somebody put an air cleaner from an LA on my L. Can anybody tell me something about this and maybe even fax me a copy of the appropriate page from the LA parts book? Thanks.
Tom Railsback
04-16-2005 17:39:24
 Re: Case L - Case LA air cleaner in reply to Steve (DE), 04-13-2005 19:29:36
As promised, I checked the L and LA parts books. THe pictures show different internal parts for sure. Also, most part numbers are different and this was done long before Case got so hot on changing parts numbers every time they needed a price increase.
Sorry I don't have a way to fax the page from the LA book.
Steve (DE)
04-16-2005 18:48:39
 Re: Case L - Case LA air cleaner in reply to Tom Railsback, 04-16-2005 17:39:24
I have just gotten to check both the pictures and lists from L and LA parts books, as well as to look closely (but not yet disassemble) mine. Yes, they are different, both in the early and late model L, and between the L and the LA. That said, I don't know how much the difference matters. It seems as if the external appearance of the air cleaners is pretty much the same throughout. The insides seem to be various arrangemnts of screening presumably in an attempt to better filter out the airborne junk. Thanks for the help. If I get smarter about this, I'll try to post what I find out.
Tom Railsback
04-14-2005 18:17:52
I'll check parts numbers Saturday after I get home from working out of town. However, I'm pretty sure they were basically the same.
Joe Peeper
04-14-2005 09:47:44
Email me and we can talk about it. Thanks, Joe
Brian in Ohio
04-14-2005 07:13:04
It's a possibility that they were swapped out sometime in the tractors history. I don't think they changed anything on the air cleaner between the two tractors.
