Oil leaks,DC case
John in Ne.
04-13-2005 14:34:07
I'm just beginning to work on the DC I bought a couple of months ago,I noticed that the worst oil leak is behind the disc brakes.Is this a pretty straight forward job to replace the seals(I assume there are seals)behind these brakes?Thanks,John.
dctom
04-13-2005 16:56:45
 Re: Oil leaks,DC case in reply to John in Ne., 04-13-2005 14:34:07
not that big of a job, just make sure you get the right seal as the late modle tractors used a bigger shaft, if it is a single disk it is smaller than a double disk tom
John in Ne.
04-13-2005 17:58:22
 Re: Oil leaks,DC case in reply to dctom, 04-13-2005 16:56:45
Thanks for your reply.Where does a guy get the rubber boots that go over the brake linkage?John.
L.Lamp
04-13-2005 18:29:59
 Re: Oil leaks,DC case in reply to John in Ne., 04-13-2005 17:58:22
The brake boots are still availiable from Case-IH for the late models '52-'54 SC and DC. I just got two sets about a year ago. I think the others are still availiable too.
dctom
04-13-2005 18:26:13
post for john saeli or don l on this board they may have them
