DB 990 - is it tough enough?
Ritchie Leslie
04-13-2005 12:28:54
I am considering using my DB 990 to subsoil. I can get hold of a 2 prong subsoiler quite cheap. Conventional wisdom seems to say 20-30 hp per subsoiler prong.
Elmer and others - is the 990 tough enough for this or should I keep looking for a smaller subsoiler? I don't want to rip the clutch apart or something if I hit a buried boulder, of which I have many.
joe e-tx
04-15-2005 19:04:00
 Re: DB 990 - is it tough enough? in reply to Ritchie Leslie, 04-13-2005 12:28:54
sorry so late hope things went ok --im in east texas. worked s++it out of my 1210DB 70 hp pulling HAY KING c8 sub soilier 6 15 inch chanks i was working 10 to 12 inches deep with colters in front cutting sod 3---6 inch dirt red clay from threr down .. good luck also have a 995 DB.
JOE
Elmer
04-13-2005 17:10:55
Dad pulled a 7 shank chisel plow with 12 inch sweeps with no problems. You should be able to do it with the hitch in the TCU selection.
jimont
04-13-2005 16:28:22
Those 990's are tough tractors and Elmer can enlighten you if they are capable of a 2 tooth subsoiler. However ,I have used a single tooth subsoiler on a Ford 5000 and popped stones out of the ground that two men couldn't lift. It's amazing how easily they pop out with no damage to either the tractor or subsoiler.
Pat Tercho.
04-13-2005 16:21:23
We have a 990 built in 1968 with 5700 hrs on it. She's tough enough, alright. Probably the only problem you'll have is traction.
Ritchie Leslie
04-18-2005 07:51:23
 Re: DB 990 - is it tough enough? in reply to Pat Tercho., 04-13-2005 16:21:23
Thanks to all for your help. I bought the subsoiler so will let you know how it goes.
