I use 15W/40 high quality diesel lubricant - something branded, not a mass market product from Wallmart or similar. Engine: There is a single drain plug on the sump. Right underneath the engine. YOU NEED A LARGE DRAIN PAN. The average car drain pan will overflow!Change the oil filter at the same time. The filter sticks out of the left side of the engine, horizontally, in a cylindrical steel holder. The oil filler is on the lhs, just behind the rad hose. U need a funnel. Gearbox: there are two drain plugs - one under the gearbox, one under the PTO housing. replace the hyrdraulic filter at the same time. The same lube is used for the gearbox and hydraulic system. Cleanliness in this job is critical. The filler is on top of the gearbox, rhs, beside the gear shift. Use a high quality combined transmission/hydraulic fluid. Viscosity depends on how hot it is whereever you are! If you are new to DB's and your tractor has been neglected, remember to clean the air filter, replace the anti-freeze and the gear oil in the final drives too.
