Auto-Lite generator parts needed
Mathias NY
04-12-2005 18:49:22
I had an Auto-Lite generator #GAS-4167 sitting the bench, just back from a fresh rebuild, when it got caught on my coat and fell to the shop floor. The mounting bracket, on the side away from the pulley, broke off.
Does anyone know where I could find a replacement? I would hate to have to pay for another rebuilt generator just to get this part.
Any help is appreciated....
C. Amick
04-13-2005 04:22:00
 Re: Auto-Lite generator parts needed in reply to Mathias NY, 04-12-2005 18:49:22
Is the piece that broke off attached to the end plate? If so, you should be able to take it off and get someone to weld it back on with a torch and some brass without damaging any wiring. If its threaded you may loose the threads, but you can always hold it on with a bolt and nut. I'm not sure I would want to depend upon J.B. Weld holding it on.
JRT
04-12-2005 19:58:50
What Kind of Case tractor was it mounted on? Was this bracket part of the generator housing or a separate piece?
Mathias NY
04-13-2005 03:48:36
 Re: Auto-Lite generator parts needed in reply to JRT, 04-12-2005 19:58:50
The generator was off a '42 DC. The part that broke was part of the generator housing.
There are 2 bolt holes on the bottom of the generator, where it attaches to the tractor. One on the pulley end and one at the opposite end. The opposite one snapped off.
