Case 511b shuttle shift lever
Frank R.
04-12-2005 14:09:35
My Case 511b has a very long handled shift lever on the left side of the tractor that enters very low on the trans case. The tractor is a triple range and has 4 gears, reverse, and each of these can be used over 3 ranges Low,Drive, High. The long lever only clicks into gear in the most forward position. Pulling it back does not engage anything. Could someone tell me what this does and how it works? I suspect it is some sort of shuttle shift but it does not seem to work.
Joe (Wa)
04-12-2005 17:21:21
 Re: Case 511b shuttle shift lever in reply to Frank R., 04-12-2005 14:09:35
The lever is a hand clutch that controls tractor ground movement without affecting pto operation.
In other words, if you are using the pto to run a baler, bush hog, or whatever, the hand clutch engages/disengages the transmission for ground movement and the pto continues to run.
Foot clutch engages/disengages both the transmission and the pto.
Joe
Frank R.
04-12-2005 18:36:15
 Re: Case 511b shuttle shift lever in reply to Joe (Wa), 04-12-2005 17:21:21
Thanks alot for the help. I will try it out next weekend. I have a service manual for this tractor but I dont remember seeing a hand clutch. I did see a section on the shuttle shift and this is why I assumed it was a shuttle shift. I will have to take a closer look at the manual.
