DB 885
PT
04-11-2005 21:10:44
I just purchesed a DB 885 with a loader. The loader has very little power and will only lift a few hundred pounds. I checked the hydralic fluid and it was white milky looking. Water I guess. The loader had lots of power only a few months ago and was used to load heavy round bales. The tractor has set for 5 or 6 months and now has the power problem. what should I do about the hydralic fluid? Thanks
Steven Meckstroth
04-13-2005 20:23:55
 Re: DB 885 in reply to PT, 04-11-2005 21:10:44
The usual cause for water in the hydraulic oil is bad boots on the gear shifters. With a bad boot, water will run down the shift rod and into the transmission.
jicaseworld.com
04-13-2005 16:41:50
Send Gord your email at jicaseworld and he will get back to you one on one. Positive he can help
Gail
jicaseworld.com
04-13-2005 17:17:41
 Re: DB 885 in reply to jicaseworld.com, 04-13-2005 16:41:50
Did you replace the fluid and change the filter?
Gord
pt
04-13-2005 19:34:19
 Re: DB 885 in reply to jicaseworld.com, 04-13-2005 17:17:41
No, I haven't repalce the fluid or filter yet. What type fluid should I use and what filter do I change. As you can probably tell I'm not very familiar with this tractor and your help is truely appreciated.
Thanks
Paul
jicaseworld
04-16-2005 06:14:32
 Re: DB 885 in reply to pt, 04-13-2005 19:34:19
There are actually 2 filters Main filter directly below gearshift assembly on the bottom of the tractor, as well a bypass nylon filter left deck side.
I've scanned the necessary manual pages and put them on jicaseworld on a link called DB885 for you. jicaseworld.com/links.html. Should be there by Saturday afternoon
